Q45tech wrote:We have now replaced 5 [in about 4years] [94-96Q] heater door for broken pin hinge.
The diagnostic only shows the position of the accuator, which is correct even with a broken door.
Systems works fine but won't switch between heat and/or cold by varying the thermostat set buttons.Usually fails no heat.
