NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Jun 09, 2005 3:21 am
Boy talk about going all out...lol
Couple things here. 1) in your first pic you show the idler pulley and the bracket is attached to. If you notice there is nothing else attached to that bracket, the pully on it is mearly for adjusting the belt. Can you say weight reduction??? remove the braked with the pully attached, say bye bye to about 2 lbs.
2) you have removed the Evaporator in your second pic which was sandwiched against the blower in your third pic. Here lies the problem. Now you have a huge gap between your blower motor and your heater core. Therefore you blower will not blow heat into the car instead you will have a hurrane goin on in the passenger foot well area. you need to do one of 2 things here. 1 put your evap case back to gether without the core in it and seal the holes where the lines went through it then reinstall it in the car. Or option 2 go to the wrecking yard and loacte a 240 without ac and rob its duct where the evap should be and put that in your car. It is a smaller peice then your evap case and is more of a flow directing duct to your heater core, this will give you a better discharge air speed.
