AC/ radio control failure
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
stangergt2000
Car: 2003 G35 Coupe with everything
OK, so I have read that there is a TSB out on this control board that seemes to be a problem. Is there anyone here that has the part number for this controller and maybe a TSB number so that when I go and order this part I don't sound like a complete idiot? Also, what seems to be the going price? Any luck on ebay finding this? Thanks in advance for anyones help.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Hey there, What exactly is happening with your audio controls there are two key parts that sometimes fail. The TSB is for a very small amount of 03s (which I see you have) however the bulletin is very specific about the failure. In my personal experience with this issue the printed circuit board (~$700) and/or audio unit failure (<$2,000). Just replacing the circuit board will not usually fix this as both components are typically needed.
Check out some of these sites there are places that can fix them and you may be able to buy a used radio and circuit boards.
shortcircuitrepair
carstereohelp
Good Luck,
There are several threads on this issue heres a good one. Dead Radio
Georgeb
AC & Radio control failure, do you still have stereo controls through your steering wheel? If you do it can be repaired @225
[email protected]
Return to “G35 and G37 Interior, Exterior and Audio”
