ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Thu Aug 24, 2006 6:58 pm
1) most likely, the latter... but if you know how to measure all the oil outta the compressor & refill the replacemnt w/ same amount---> you're ahead of the game.
2) most likely as well...since exposure to ambient air/humidity may have saturated the drier to the max...
3) if you let him do #1 & #2, well, you may want him to add an in-line filter if the compressor is confirmed that it's kaput.
what other checks did he perform/ i mean all compressors turn on-off depending on if the various switches has been tripped; did you actually see him put gauges on the high-low sides of the system???
if not, i'd go for a 2nd opinion
