He's right that is the looks like the same one on mine.JNM240 wrote:The only AC lines that should be different are the ones that actually go to the compressor, since the compressor is different between SOHC and DOHC KAs. They both use the same evap and drier, so if your line going from drier to firewall is messed up, then a DOHC should fir it.
A screwdriver tip to the inlet. push down that pin in the center. or a sawzall to the line will do it.That1Guy wrote:What the best way to discharge the refrigerant from the line? I know is illegal but it get hot out here. At lease for me.
