NJGuy »
https://forums.nicoclub.com/njguy-u191160.html
Thu Aug 04, 2016 6:44 am
The amount of refrigerant they put back in the system can significantly affect cooling performance. Too little, while uncomfortable, is ok; too much, however, could lead to damage of the A/C components.
If the shop is reputable, they would have collected the refrigerant, put a vacuum on the system after the radiator replacement and reasembly of the components, and refilled the system with the proper weight of refrigerant. That number might even be on a sticker in the engine bay or on the underside of the hood. Somebody correct me if I'm wrong, but if the system had gotten air in it, the drier/accumulator may need to be replaced as well.
I'd say to take the car back as soon as you can. While I've never had to do a full evacuation and refill of refrigerant, it shouldn't be too hard for a trained individual who does it on a semi-regular basis to do the job properly.
NJGuy on Thu Aug 04, 2016 6:52 am, edited 1 time in total.
