nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Thu May 08, 2014 6:48 pm
Is the air at least cool?
Does it change when you drive it?
Did the tech tell you the readings? WHat was the outside temp at the time?
When you changed to 134a, how long was the system inop? There is so much to the system that most people do not understand. If the system was blowing hot before and for longer than a week, you must replace the drier. If not there was too much moisture in the system. Also did the tech change the oil to PAG 100? If he didn't, that could be a huge issue. Not draining the old oil, adding too much oil, will all cause the system to perform very poorly.
Personally, I would take it back to the shop, tell them to how you the readings and tell them to either do what they are supposed to do or give you your money back You should be at 35-50 on the low and 260-310 on the high side for our cars, all is still dependent on the outside temp. If the system calls for, say 24oz, you need 15% less if converting from r12. I know this is a lot to take in, but there is a lot to a climate control system.
If the line is cold, it should be freezing feeling, not just cold. HOw does the other line feel? It should be actually quite hot. If it is not, you have a block in the system. The pressures will show that, I think the shop is full of crap if they say the pressures are good.
