qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sat Jun 19, 2010 11:53 am
If you have "done the compressor twice" , what happened to the new one you just put in in 2008? Why did it die already? Why did the one you put in THIS YEAR already develop problems???? Either you are using old used junkyard compressors , cheap rebuilds, or the system is clogged with debris "metal shavings" from the blown compressor{s} and not being flushed properly causing your replacement compressors to fail extremely early.......why A/C work is best left to a true professional {a/c trained specialist}, so many owners and gas station type "mechanics" tinker with system and create even bigger hard to diagnose problems down the road from not following procedures and taking shortcuts.
Get the car into the hands of a A/C specialist shop for total system checkup and analysis........plan on spending quite a bit to correct for past shortcuts.....most likely they will recommend replacing condensor/evaporator/dryer/ and probably yet again the compressor AFTER THEY COMPLETELY FLUSH out all wear causing debris from lines, etc- best guess......$ 1500-2000 to repair in a fashion that will allow multiple years of reliable operation. Afterall the original factory installed compressors last 10-12 years and 200,000 miles.........
