elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Jul 11, 2007 3:09 pm
Symptoms... AC starts out to be pretty cold then sorta fades off. Evap may be freezing..
Test procedure- Set AC at max cold, max fan, recirc, drivers window open, idled for 10+ mins at 1500 RPM (all specified by FSM)
After this time setting, pressures as read by my manifold gauge.
Low- usually around 30psi sometimes jumping up to like 33, no more than 35, then settles back to to 30 for a bit, then will jump.
High- pretty steady at about 175PSI
Outside temperature, roughly 75F with low humidity
FSM SPEC:L- 27.6-31.0H- 178-208.
Now at 175PSI im bordering on spec, and the low side is bordering on too high. Of course we are accustomed to that being a compressor related issue. However, with it being so close is it possible that there might be something else I could do to at least make the issue not so bad...
I just dont think its as cold as it should be.
Any comments appreciated. I will probably test this again as I think I may need a new seal for my gauge.
