At the time, I complained about the window not going up all of the time with the one touch. They didn't find anything wrong, so I just let it go knowing it would probably get worse.
SO, today I check the temp coming out of both the 04 Coupe and the 08 Sedan after running them both for a while on recirculate.
Coupe = 54 degrees
Sedan = 42 degrees
And, the window still doesn't go up all of the time. The work around is to push it down, them try again. Also, the window will not go up by inserting the key into the door.
It tries - makes noise, but then fails.
My extended warranty is good for another 12K miles/14 months.
What do you guys think or what would you do??
I have ideas, but would like some input.
Thanks!!
