AC not cold if <60 degrees selected?
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
uncbeers
I'm wondering if this seems right. Basically, if I have my A/C on, it blows cold air if the temp setting is 60 degrees. However, the second I turn it to 61+ degrees it blows warm air. If I was in the arctic this may make sense but here in CO where we have had 20 some days w/o rain and record setting heat, it doesn't seem right. If I select 65 degrees, shouldn't the car be trying to get the interior to 65 degrees? Is my logic flawed?!
This is on my 2005 G35x by the way...did not own prior to this summer so I don't really have reference to what may or may not be right.
Thanks!
Slider4105
Car: 2008 G35 Journey 5AT
I don't know how to fix it, but I remember reading about someone else having this problem. If you just hold tight someone will be along and will give you the info you need.
uncbeers
Slider4105 wrote:I don't know how to fix it, but I remember reading about someone else having this problem. If you just hold tight someone will be along and will give you the info you need.
Thanks! I mostly wanted to confirm it is a problem. If it isn't an easy fix I can utilize the warranty. That is what it is for, right? I also need to have them fix my back doors that don't open from inside (NOT the child locks-guaranteed! )
joe603
Car: 2014 Durango R/T
Definitely a problem...have the dealer fix ASAP!
uncbeers
joe603 wrote:Definitely a problem...have the dealer fix ASAP!
Figured as much-thanks!
Should I have to pay anything? I'm not 100% up to par on what the warranty does and does not cover? I'm the second owner of this and don't have every service record but I hear they can't deny based on that anymore, right?
Slider4105
Nah everything is in the computer now. When I took my car in they put all the info in from my vehicle and said that anywhere I go they can pull up my service record, I think it wa based off the VIN or something.
Return to “G35 and G37 Interior, Exterior and Audio”
