ac line help!
turbo2nr
Car: 97 240sx (kouki)
damm freakin ac.... grr.. damm it i should of went rb.....
im almost there now that im makeing everything all snug and nice the freaking a/c line is less then 1/2inch form my downpipe!
so can i move it or reroute it some where else i dont want it to melt or lead to bigger problems.. ill get a pic tomorrow of the damm lines... just one freaking thing after then next.. i just want some boost is that to hard to ask for?
lrb_2000
Car: '91 Nissan KA-T hatch
get rid of it?
turbo2nr
no im a lazy america and i need my comforts of a/c plus i had a old car wid no a/c in the summer... it wasnt very fun....
WDRacing
AC rocks...I totally agree. If its not a track car, then keep the AC. Can you not bend the AC line out of the way. Or heat wrap it?
WD
turbo2nr
na its pretty tight, just the way i ususally like it lol..
but seriously this realls stiff and hard to move. will wraping it really help with heat?
WDRacing
Take a picture, I need to know what line you're talking about...HURRY UP!!!
Chezedik
Car: 1991 Nissan 240sx
Yeah, mine blew up about a week ago when my DP burned a whole in it. Some NAPA or CarQuest locations can custom make you a host, so that you can lengthen it. Be sure to charge the system based on pressures, in order to get it right.
halnfl
Car: cars, woman
Where the junction is behind the head you can tweak it down a little and put heat wrap on that and your dp and it should be fine. I did that to mine and have been running it like that for about a year with no a/c problems.
Chezedik
Yeah, I know now! But seriously, I had my DP ceramic coated, because I was told that it would be a good enough insulator that I could touch it after boosting. The burn I received told a different story. I may change the line later, but now I have to change the accumulator, so this will be an expensive job that will probably wait until I am in the desert (if I make it there...).
