topdowninaz wrote:94 240sx
AC light turns off when I slide the fan up to 4 then it seems to blow warmer. It blows cold and the AC light stays on when at 1, 2 and 3 but gets noticeably warmer when I turn it up to 4. Have temp set as cold as it will go.
Any ideas............of course there are.
does your compressor kick off when the light goes out?or constant on then off every few seconds?if so you are eather under charged or over charged,most likely under charged unless you have had a/c checked lately.and if non of the above I'll have to agree with nistech and say it is your switch.
