bataradena »
https://forums.nicoclub.com/bataradena-u9107.html
Thu Aug 28, 2003 4:15 am
Well to finish up this thread I found the problem. You will not believe what I found. The gourmet that is used to seal between the hard plastic drain line and the soft drain hose located on the firewall was not installed completely, leaving an opening inside the passenger side. I believe this condition has been this way since new. Thanks again…
