SpecDRacing »
https://forums.nicoclub.com/specdracing-u28175.html
Wed Jun 22, 2005 2:37 am
As stated, bogging in hot weather is a bit general of a description. The AC shouldnt cause this, even with a low charge. Make sure, if you do go to add R134 to your system, that you have ir properly checked for the amount aleardy in the system. Overcharging can lead to an underperforming AC system, loss of cool air, or even a/c component damage. Preasures in an AC system reach in the in the 180-220 PSI range depending on vehicle, so overcharging can definately damage or malfunction the system. In some cases, the system wont come on at all as the cars diagnostics will see the excessive preasure and dissengage the ac clutch.
As for power loss, you should start with the basics. Has your air filter been checked recently (Q45's are known to cake an air filter in no time, J's on the otherhand stay relatively clean for 15-20 thousand miles). Has the fuel filter been replaced? Spark Plugs? Etc. As these little things can add up to a big power loss.
If the car runs good and doesnt have the MIL on, then I'd say just keep up with your routine maintenances and it should be ok (or your mechanic will let you know). Sometimes, we find ourselves worrying that our cars are acting funny....only because we beome more aware of their characteristics. If your still worried about this, just fill us in a few blanks and we'll be glad to help.
