ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Fri Mar 07, 2003 9:06 am
I don't know any specifics on how to tell you to do it, but how the a/c compressor is activated is through a power signal. What has to be done is the compressor is connected electronically to the console controls. The console controls are connected to the ecu and ignition power. If your wiring from the ecu to the console is correct, then all you need to do is have the correct wire/s go to the compressor. You might want to look into wire schematics or call someone who knows, like Heavy Throttle.
