DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Jul 17, 2005 9:54 am
The last thing you want to do is convert the type of refrigerant used. The old stuff (R12) is 10x more expensive, but it doesn't need new parts, or a complete system flush, and it works better than the new stuff (R134a). Plus there are no contamination issues. So Jiffy Lube filled the system with R134a? This could be a big problem unless the system was completely flushed out to get the old oil out. The burning smell is usually the belt burning, which in indicative of either a bad tensioner or a bad compressor, or both.I'm sorry, but it doesn't sound like there's a cheap fix to be had. The system will need a complete flush if it hasn't yet had one, plus a new drier, plus whatever is broken.
