NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Dec 05, 2003 9:54 pm
it is the mode door actuator. the inner gears of it are binding and it is stripping the gears. the reason it continues to make the noise is because the actuator his limit switches and its looking for the limit switch while its trying to adjust to the requested location. since it is bound it never reaches that limit switch in its travel. therefore the motor continualy runs and pops on the gear teeth(your audible clicking noise). replace the mode door actuator and it will be all good. to find it under your dash turn the key on and put it in one of the positions that makes it click. poke your head under the dash ,probably on the passenger side, look for a rod snapped into a white clip on a small black box that is jerking in unison with the noise. that black box is your actuator replace the box.
When you go to install it set your controls to defrost. plug the actuator in and watch the movement of the arm. which ever direction it went is the direction you need to push the steel rod as far as it will go(no force needed just as far as it will go freely) then with both of them in that direction snap the rod back into the actuator. Test all modes and it should be repaired.
