AC/Heat only blows on the High setting
jaysq
Car: 1997 Q45
Anyone else with this problem please advise. My 91 Q only blows air after I manually turn up the speed to the last fan blade. On automatic it does it also but air only moves when the fan blades fill up on the readout(high). Do you guys think its a short in the fan circuit or something else. I went through the diagnostic in the service manual but the last 40 or so pages are missing out of the book. I'm pretty good aroung circuitry so let me know what I need to do. Any help is greatly appreciated. Thanks.:help
qship96
Car: 1996 Infiniti Q45
most likely the fan resistor is bad,had that happen to me before,cheap repair at the dealer!
Q45tech
It is not a resistor it is a high power darlindgton transistor which receives a bias voltage from HVAC controller. Top speed is supplied by a relay which places 100% of battery voltage to the fan motor other times the voltage is supplied thru transistor.........transistor blows apart internally and is open circuit.
This happens when the fan motor gets old and starts drawing too much current..............replace the unit, if it keeps blowing change the fan motor also.
jaysq
Car: 1997 Q45
Change the climate control unit?? Or can I find and then solder out, then solder in a new transistor?
Q45tech
The transistor is in a plug in package with a heat sink in the air flow [HVAC assembly] behind the glovebox.Order a new one fom Scottsdale it will become clearer when you see the unit.
jaysq
Car: 1997 Q45
Thanks Q45. If your listening Joe, how much for the HVAC assembly mentioned above?
