The issue is when I start the vehicle and the air is left on it used to start blowing right away. Now it doesnt start blowing right away. I find that changing modes, temperatures, and fan speed does nothing. However it seems that switching the defroster on and off starts it blowing again. Other times I will hit a bump and it will start to blow right away.
Prior to this absolutely no issues what so ever with heat/AC blowing as soon as I turn the vehicle on. It only started after the valve cover gasket was changed.
The harnesses in question are labelled 1 and 2 in my image. Everything else was left connected and folded over to the right of the image onto the intake manifold.
My question is does either of these harnesses directly relate to the AC/Heater control module blowing air?
