GseaQ »
https://forums.nicoclub.com/gseaq-u329.html
Fri Aug 07, 2009 9:04 pm
Thanks guys. Unfortunately we pay a premium for most things up here in Canada. Joe's price is good for you, but after the shipping and exchange rate for our dollar it'll still be $75 for me (I have stuff shipped to WA to save $ & aggravation). If the 96 Pathfinder/QX4 is the same I can get that at NAPA here for $35.
This is the piece of s*** Q I bought from moderator Rex. I've changed the transmission, steering rack, differential, much of the front steering/suspension, an injector and all injector o-rings, knock sensors, radiator, engine fan blade, belts and now the AC compressor. The interior is still permanently stained and the paint is still peppered with rock chips. I can't justify paying double the price for parts anymore for a car that is basically worthless and will be thrown away in 2 years unless I have to. I'll take apart as much as I can in the driveway to get to the expansion valve to save on paid shop time, maybe I can even change the valve myself. The system is empty after all.
The original compressor started making some intermittent light knocking. At that point damage is already done to the system, but it still blew cold. When the cold air stopped I noticed the knocking had also stopped. The compressor clutch still engaged, so I figured the thing finally broke. I bought a used compressor and a new receiver drier. The system was evacuated, vacuumed for a half hour and recharged. When the replacement compressor didn't make cold air the system was evacuated again. When I got the remanned unit installed the system was vacuumed again for a half hour and re-oiled and recharged. Now that's been evacuated again. I think the system should be clean.
Modified by GseaQ at 12:14 AM 8/8/2009
