My ac runs low on refrigerant in 3 weeks. I added enough to get the high side up to about 225 when it was 95 degrees. I placed my "sniffer" in the main vent and it went it started beeping. I did this a couple of times with the same results. I did this as I could not find a leak anywhere else. I am assuming an evap leak. Thoughts? Also to access the expansion valve, is it necessary to remove the intake manifold? I can't see an easy way to remove the expansion valve.
Thanks,
Joey
