Infinitiguy19 »
https://forums.nicoclub.com/infinitiguy19-u84424.html
Tue Sep 13, 2011 4:53 pm
Can you guys please take the time to read through the service manual?
The fan comes on/stays on with the IGNinition switch "ON" or "Start" position. And that's only if the pressure in the Air Condition system exceeds a specified value. Or if the temperature of the engine as reported by the thermal transmitter reaches a specified temperature. The ECU will ground one or both relays till the sensor reports a lower temperature to the ECU.
So as I said before you may have a 1990-1993 Q45 ECU, A NICO ECU (modified 1990-1993 Q45 ECU) or a defective thermal transmitter circuit.
You can rule out the relays by using a real Nissan Consult 2 or OBD Scan Tech Nissan (With the proper cable of course).
