Postby
mrjunior »
https://forums.nicoclub.com/mrjunior-u94535.htmlWed May 27, 2009 7:42 pm
Hi i'm a owner of a i30 infiniti before when i hit the throttle hard & the car goes above4 rpm the A/c shutdown now it doesn't do it any more what should be wrong???
Postby
mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.htmlFri May 29, 2009 6:31 am
Should just be the full throttle switch in the TPS. You might just need to adjust your TPS a bit to fix it, which is pretty simple to do. The whole process should be listed in the proper FSM here: http://www.nicoclub.com/FSM
