AC Display rarely works, power antenna won't budge
Photo_Puri
Car: 1992 Infiniti Q45
Couple of minor problems going on the '92 Q45. The electronic display for the AC won't come on for me (although my sister did mention it turning on a couple of times). Any ideas on where I should start looking to fix the problem? Everything still functions correctly, hard to adjust the fans and temp on a car you just got with no display though.
Also, power antenna is stuck in the down position. We still get okay radio reception, but I'd like to have everything functioning. I'm assuming the motor has most likely died out? Common problem at all?
Q45tech
WelcomeBoth these things have been discussed in minute MINUTE detail at least QUARTERLY over the 7 years I've been here. Especially thing know to have occurred since 1991.
First one needs to accquire a FSM and read the thousands of pages of how to just as dealer technicans are forced to do to solve many problems. Or skim a few hundred thousand posts, use our search engine, or check our how to section.
dsagers
If you can hear the antenna motor running, then you need a new mast installed. If the motor is not running, then you need a replacement antenna motor assembly.
As far as the AC display, these often failure after a few years, either they do not display or they no longer control the heat & AC functions. A replacement control for the heat / AC is easy to remove and replace. First time will take some time, after that its a 15 minute job.
Replacing both the antenna and AC control is described in the service manual.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Hi and welcome to Nico
Regarding the A/C display, it's a common problem. You can buy a used one from eBay or you can have yours repaired through:
http://www.jerrytucker.net/
The antenna problem could be either the mast or motor, or even both. I replaced my mast with a new oem one (not expensive) and it goes up nice and smooth, but still sticks when going down and I have to turn the radio one and off repeatedly to get it to fully retract.
In case you don't have the factory service manual, you can download from here:
http://www.nicoclub.com/FSM/Q45/
Be sure to visit:
http://www.q45.org/
http://www.nicoclub.com/subpag...l#q45
Modified by lino at 10:37 AM 8/21/2009
silkysmoothyjud
Car: 1994 Q45
Believe it or not an "antenna X" replacement works great in my Q (wired to my phoenix gold amp, I'm so hood). You can get em on ebay for 30 bucks: OEM is 200$ ouch!!!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
silkysmoothyjud wrote:Believe it or not an "antenna X" replacement works great in my Q (wired to my phoenix gold amp, I'm so hood). You can get em on ebay for 30 bucks: OEM is 200$ ouch!!!
I don't know how much your stealership jacks the prices up but MSRP is: $88.55 and IOS price is: $66.41.
http://www.infinitipartsusa.co...gid=0Now if your talking about the assembly then yes its $314.23 at MSRP and $235.68 from IOS.
IOS=Infiniti Of Scottsdale------------------------------------------------------------------------------------------------And not trying to one up you Lino:
Prod.M/Y:0891-1291-----Part number: 28525-60U04-Prod.M/Y:1291-0492-----Part number: 28525-60U05-Prod.M/Y:0492-0293-----Part number: 28525-60U06-
The above two supercede to the last part number: 28525-60U06-
Modified by Paul Wall at 11:13 PM 8/20/2009
Q451990
Long story short, 90-93 climate controls are all interchangable. I have purchased numerous ones out of junkyards and ebay when I can get them cheap. Most of them are bad. Interestingly enough the two working ones I have came from very early production 1990 models.
Heath
Photo_Puri
Thanks guys. Definitely gonna go with dsagers used parts.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
i agree about going with jerry tucker, buying a used one would be good for a core so you dont have to send the one in out of your car...
dsagers
Yo
Photo_Puri wrote:Thanks guys. Definitely gonna go with dsagers used parts.
You have mail
