Jesda.
Looking back in the FSM, there IS no code 20. Code 21 is the next nearest, and i dont think thats your problem.... It may have been code 22, cant remember for sure......
Sorry short term memory is bad!
Go back out to the Q, turn the ignition to on, not started, and hold OFF until the display does the segment check. Then press warmer, you should get a 2, it will think for a second, and then display a code... CODE 20 means everything is golden.....
