Your vent selector motor is shot,working when it feels like it, or is getting stuck. best bet is to keep it on the dash vents, but after i show you how to dougie, u can manually switch it back.
lay on ur back and look up to the side of the dash from the drivers side you will see this white plastic boomerang mechanism that moves and selects which vents to open and close. turn your dash buttons to blow on the face, and manually turn the boomerang far counter clockwise as you can until its in this position. the white tab will meet the end of the metal guide rail.
Uploaded with
ImageShack.us
this was a post for an S14, but may be similar.
