ardvarkus »
https://forums.nicoclub.com/ardvarkus-u150.html
Fri May 14, 2004 5:17 am
You need the schematic to trouble shoot it.
Figure out what should turn it on, then why it isn't working- either a relay or switch is bad, or the motor is fried. As Q45tech mentioned, jumper the CORRECT contacts and the fan should work- if it doesn't, replace it!
I don't have the 92 schematic- look in the back of the service manual
A
