luvmyq45 »
https://forums.nicoclub.com/luvmyq45-u572.html
Mon Aug 12, 2002 12:52 pm
This might be your clutch wire. I had an incident a couple years back when a pulley seized up (driving back from an Infiniti dealership after they had replace all my belts), snapped the belt and sliced this wire within 1 inch of the compressor(clutch). I managed to strip enough insulation off the wire and tin it, filled a butt connector with solder of which I've already connected the other side, and slid it over the short stubby stripped wire (sounds easy, but it was a several hour job, over an hour just to strip the stubby wire!). It has worked ever since. At least until my compressor died this summer.
