Serdriver »
https://forums.nicoclub.com/serdriver-u291991.html
Sun Sep 01, 2019 8:21 am
Hello,
New to the forum, but not new to fixing my own problems. I’ve been reading through the stickies and found lots of great info (how to fix my broken clock, the PÍA to replace the stock head unit, etc) so thanks in advance.
I just picked up a 2001 Pathfinder LE with non working ac and have a few questions.
Blows warm air really well, all fan settings work, and the heater works great, and I san move the air to different vents. so I checked the low pressure side to see if I needed coolant and it was HiGh, red zone high. So I released some pressure and a bunch of yellow/green dye came out. Got it back to the blue green zone so it’s not over pressurized. I can’t hear the compresor clicking, but (with the engine off) I can turn the clutch by hand but it doesn’t spin on it’s own (does this mean it’s NOT seized, right, because I can spin it by hand?)
This makes me think the ac lines are clogged but maybe the compressor is actually still Functioning? I think it’s clogged because the former owner tried to see if there was a leak with the ac dye but it didn’t really go anywhere, just stayed in the low pressure line.
I think I I have 3 options (and this is were I could use some advice).
1) vacuum out the ac lines to see if any moisture/air gets out and then refill the ac system to see if it works. This would be minimum cost because two cans of ac recharge cost about $30 and I can rent the vacuum from oreilly. I’ve never used one before , but doesn’t seem to difficult.
2) replace my compressor, along with drier for about $200. (And yes, Im changing my belts too!)
3). Replace the compressor, condenser and drier and expansion valve for $300. All these parts would come from Rockauto. I’ve done this before on a Subaru, so I’m familiar with the process and I wouldnt have to guess if anything works or doesn’t work.
Anything else I’m missing. Reading over this it seems the vacuum part is easiest and most cost effective, so I will probably try that first.
Any thoughts? Thank you in advance.
