Folks,
Have an 01 LE Pathfinder w/o Navi but w/ electronic HVAC controls. Heater seems to work fine - AC does not blow cold. (Blower motor works fine and vent doors seem to be operating normally)
When AC is turned on while parked and I try to maintain a a fast idle ( 1500 rpm or so) the engine will stumble regularly, almost like it stops/starts/stops/starts/stops etc. Turning AC off smooths the engine out after a second or two. Engine does not appear to stumble at higher RPMs.
AC was serviced 2 yrs ago and dye checked.
I think I hear the compressor coming on when I engage the "on" button
Could this be a relay issue? bad compressor?
Any other suggestions?
Thanks
Thanks
