AC Button lights up when I turn on fan control ???
PB
Car: 2007 Nissan Versa S
Why would my Ac button light up when I turn my fan control on 1/2/3/4,My tempeture control lever is to the hot the red side for heat,If i press the buton for ac to turn it off it will turn the light off,When i turn the fan speed to 0/off and then back on same thing,AC lights up,Can some on here check this and see if yours operates the same,Is there a defect in the versas??
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
Just a guess, your selector switch is set to defrost or defrost/floor?
If so, the A/C will automatically come on, as it helps dehumidify your interior faster.
Try moving the selector switch to vent/floor and the air selector switch to fresh (not recirculate) and it should be off when you turn on the climate controls.
boxcarbill
Car: '07 Versa SL hatch 6 speed white/beige int.
the owner's manual says it's to keep the ac lubricated by operating it on occasion. Yes, it comes on in the defrost position.
I also suspect the car mixes ac and heat to produce less cooling on the temp control so if you have the ac on be sure the temp controll is fully ccw. If it gets too cool turn the fan down or crack open a window.
PB
Ok Thanks,I played around with it ,And it seems that it stays on no matter what you do with the control knobs.I thought i check up to see if we have a problem no one knows about.
