ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Fri May 16, 2008 10:13 am
probably needs a new evap, as stated in the other response. Hope it's an O-ring though. DO NOT use those cheap "death kits" for recharging your A/C. They often do more damage than good. They ONLY time they are OK is on an old junker car that slowly loses refrigerant and when the pressure gets low enough to shut off the A/C, you can add some from one of those cheap kits so long as the system isn't completely empty to start with. On the last A/C compressor job I did ('99 Buick), the compressor kicked on after only adding 10oz. of refrigerant in the system which is full at 2.25lbs. So just adding one 12oz can when the A/C shuts off due to a slow leak is usually not even close to enough to bring it back to full. If you've got a big leak where it all leaks out, you need to find the leak, fix that, drain compressor oil, fill with correct amount of proper oil, vacuum the system down, and then re-fill. If the system has bee open to the outside air for more than a few hours, it's a good idea to replace the reciever/drier at the same time as it contains silica which absorbs moisture from the air and can quickly become saturated if left exposed to outside air.
