I took the actuator off and cycled the door manually, I can hear it open and close. The air changes from floor to vent to defrostVStar650CL wrote: ↑Sat May 01, 2021 4:44 pmMake sure the blend door actuator key isn't stripped. If it is, the motor will turn but the door won't move.
No, there shouldn't be anything else in the path. The only other cause we see is, on some models the evap is below the heater core and water from a blocked drain can drown the evap. However, that also causes a reduction in airflow when in the "cold" position. Did you check the keyway on the door, though? The door may be free but it won't move if the keyway on the door or key on the servo are rounded off or stripped.
before you do that, did you look at the troubleshooting section in the FSM?
There are actually three door motors in the HVAC system. The evaporator always has air passing through it and is never blocked. The door you are describing here that changes air flowing to the floor, vent, and/or defrost is controlled by the mode door motor, which is operated by the air flow direction knob. The mix door is the one that seems to be stuck open, fully exposing the heater core to the air flow and making your system always blow hot air. The mix door motor or its linkages to the mix door may not be allowing the system to blend the air flow properly. The mix door motor is operated by the temperature control knob. The other motor is the intake door motor which operates the door to recirculate your cabin air or bring in air from outside.nicv21 wrote: ↑Sat May 01, 2021 5:25 pmI took the actuator off and cycled the door manually, I can hear it open and close. The air changes from floor to vent to defrostVStar650CL wrote: ↑Sat May 01, 2021 4:44 pmMake sure the blend door actuator key isn't stripped. If it is, the motor will turn but the door won't move.
Is there another door that blocks the evaporator? I can reach under the plenum on the pass side and feel its cold
Absolutely! Check out the FSM first so you know where all the bells and whistles are located and how to troubleshoot the issues. I also just realized, after looking at the '01 manual, my '02 has control knobs for air flow direction and temperature but your '01 may not, depending on what model you have (LE, SE, or XE). Mine is more manual-mechanical as opposed to electro-mechanical controls.04pathse wrote: ↑Sun May 09, 2021 8:24 ambefore you do that, did you look at the troubleshooting section in the FSM?
Also it looks like there is a self-diagnosis test you can run that might be helpful, instructions
are in the fsm
https://www.nicoclub.com/service-manual ... 1%2Fha.pdf
Or just one. Now that I have looked at this in more detail, the models with manual control knobs for air flow temperature and direction are purely mechanical for operation for the mix door and mode door. There are some electrical elements to the controls put those doors are opened and closed solely with cables and levers, pulled and pushed by rotating the knobs. This should be an easy fix to find the missing link, so to speak, if it's a manual knob controlled model. Check out pages HA-181 and HA-183 for the cable a lever controls for these two knobs. https://www.nicoclub.com/service-manual ... 1%2Fha.pdfVStar650CL wrote: ↑Sun May 09, 2021 9:29 amFour if the OP has Auto A/C, there will be separate mix doors for driver and passenger.
Not to mention you could drop the whole engine and drivetrain in ten minutes whenever those air-cooled pistons gave up. Had a buddy in college with a Microbus that had 375K on the clock, but he'd never mention that it was rebuilt 5 times.
Flat 4, OHV, not flathead 4.
I was into aircooled VWs once upon a time. Living at the time on dirt roads I was so proficient at replacing piston rings one time I did a ring job, then didn't even start it up before embarking on a 500 mile trip. A couple of hours, almost like an oil change. I'd love to drive an old bug or bus again. Briefly.Not to mention you could drop the whole engine and drivetrain in ten minutes whenever those air-cooled pistons gave up. Had a buddy in college with a Microbus that had 375K on the clock, but he'd never mention that it was rebuilt 5 times.![]()
MD Mellott you win the prize! I took out the mix door actuator, and cycled the door by hand and voila! the A?C blows cold! Now I have to figure out it the actuator is bad or one of the sensors. I cycled the temp from 65 to 80 and back down again and the actuator did not respond, and it does NOT move by hand, IDK if it is supposed to.mdmellott wrote: ↑Sun May 09, 2021 10:59 amOr just one. Now that I have looked at this in more detail, the models with manual control knobs for air flow temperature and direction are purely mechanical for operation for the mix door and mode door. There are some electrical elements to the controls put those doors are opened and closed solely with cables and levers, pulled and pushed by rotating the knobs. This should be an easy fix to find the missing link, so to speak, if it's a manual knob controlled model. Check out pages HA-181 and HA-183 for the cable a lever controls for these two knobs. https://www.nicoclub.com/service-manual ... 1%2Fha.pdfVStar650CL wrote: ↑Sun May 09, 2021 9:29 am
