ac belt slipping
johnshop
Car: 1995 nissan 300zx na 2+2
so it's quite annoying, my ac belt slips every time i turn on the ac, is not constant, but it goes off for a 5 minutes and then starts making noises again and then goes off and then noises again, so i was thinking it may need some tightening, how hard is it to do? i was looking thru the FSM and i did not see anything on that point, or i am just a bad reader?
if someone could please help me and point me into the right direction it would be greatly appreciated.
aroche25
Car: 2007 Mazdaspeed 3 GT
Looking for a Z32 Slicktop
You may find this handy (belt-adjustment-t365646.html) just read the whole thing, it tells you were all the adjustment points are for all your belts.
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Are you sure its the belt and not the compressor clutch?
johnshop
I don't know, to my untrained ear just sounds like a belt slipping, how could I know if it was the compressor clutch ?
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Is it squealing? Doesn't take long to tighten, just read the post mentioned above
t.mcginley.jr
1966 Ford Mustang
Tighten it up, if it doesn't go away after that then it's something else like a bearing. Some people say to put this thing called "belt dressing" on it but I've never had to use that stuff to keep belts from squealing.
johnshop
hopefully this weekend i will do the tighten, i should remove the radiator for easier access?
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
No, just put it up on jack stands and get underneath it. jack stand points
The tensioner pulley is there on the driver's side.
