Ac Belt Removal
oxs1
What are the causes if the Ac Belt is to be removed from my Q? Power gains? Power loses? Pro and Cons?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Try again, please. Can't understand the question.
It is a question, is it not?
I second what Brian said above.
My guess is that youre asking us why your AC belt disappeared?
The same happened to me when the idler pulley, which the belt goes around at the bottom, seized up. In your case, it could also be a seized compressor, which gets expensive. The pulley is easy to remove and replace, and the part is cheap (http://www.everythinginfiniti.com).
Dennis (Q45tech), if I recall accurately, says compressor failure is caused by a failure to reoil and flush the system regularly.
Get under the car and look at the pulley at the bottom and see if it rotates, or if its frozen. If you get one pulley replaced, it would be wise to do all three at the same time.
I once let a water pump/power steering pulley fail, at which point the belt snapped off, my power steering died, and my motor overheated briefly -- left me stranded in a parking lot at 2am. A seized pulley worth a few bucks could have resulted in thousands of dollars in damage, but I was lucky.
-Jesda
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Are you asking if you will increase poser, by disconnecting the A/C belt?
Very little power increase, over turning off the A/C. Your compressor has a clutch, that allows the pulley to free-wheel, when the A/C is off.
fxjackso
If you have a teeny little four, it seems like the a/c uses half the power, because it does. If you have a big V8, it doesn't matter much. Not enough to give up A/c in the summer, anyway...
