gawdzilla wrote:if you don't have either why wouldnt you just remove the pumps altogether instead of their pulleys?
but anyway, those pullies stick out no further than the crank pulley, so no you don't need to remove them. if you're running e- fans you most likely need to put the fans in first, then the radiator.
radiator and fans attached doesnt really fit.
i didn't think i had the pumps, just the pulleys. i am confused now. well the pulleys in question def. stick out the front more than any of the others. it's llike my belt is on 3 pulleys and the bottom one has 2 extra ones coming off of it that are not being turned by the belt. i have 2 puller fans, but there is no way they will fit with the extra pulleys and the new radiator. i might have to use a pusher fan.
