hokiruu »
https://forums.nicoclub.com/hokiruu-u3429.html
Wed Nov 19, 2003 10:48 am
Wuss, I had this problem too. Turns out I had a bad ignitor. Get a test light, turn the key to the on position, and test for current at both ends of the ignitor. Interestingly, a bad ignitor can have juice on the side the arrow on the ignitor is pointing toward but not the other. That's how I discovered my problem. I may have current at the coilpacks themselves even, but a bad ignitor (one of the three wires to the coilpack) will prohibit signal from being sent to the coilpack.. Check all the connectors for juice from the coilpack back, and make sure they all snug. Sounds to me its probably the ignitor chip though, as it is a very common problem.
