rbunch4468 »
https://forums.nicoclub.com/rbunch4468-u80129.html
Thu Aug 04, 2016 6:14 am
I have a code from my ABS that says each one of the front wheel sensors has an open circuit. When I measure the right front sensor resistance, I get 1.6K ohms. The correct range is 0.9 to 1,1 k ohms. Would this be enough to make the ABS electronics report an open circuit? I am concerned that both sensors report 'open'. Sounds like it would not be likely. My issue is that I can fix the sensors for a few hundred bucks in parts, but if it is the ABS electronic system the fix would be more than the truck is worth (~ $2k).
Any help you can provide would be welcome!
Rick
