ABS vs. Non ABS Drivshaft Fit
Bostis
Car: 2005 Nissan Sentra S 1.8 AT
2005 Sentra 1.8 S non ABS: Will ABS replacement driveshafts work in non ABS vehicle? And, if so does the sensor ring need to be removed to fit?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The parts catalog only shows one hub fitting all the 1.8S variants, with the ABS reluctor ring being a separate part from the hub and axles. Since the hubs are the same the splines should be identical as well, so my guess is the CV axles should interchange.
Bostis
So, no need to remove the ABS reluctor ring?
VStar650CL
Technical Expert
I don't think so, but they are removable if it turns out there's interference with the spindle.
Bostis
Thank you VStar650CL.
