Hi , informative thread, wondering if anyone can help me investigate something further on this VDC topic.
have a rogue 09:
-brake fluid went down to min i topped it off.
- I did not notice whether or not VDC /slip light was on or not before hand
-since then after ignition the VDC self-test seems to fail (i hear this motorized disengage sound, and the slip / VDC Offf light both come on)
-I read that this might be due to worn out brake pads or rotors
-I replaced my rear brake pads and rotors
-VDC Off /Slip lights still come on, same motorized sound
I am assuming that the self-test diagnostic for VDC is failing and the system shuts it down after ignition and I move the car at very low velocity.
Is there a way to find out what diagnostic tests are running so I can find out what exactly is failing?
I have found this page that describes some of the ABS tests, just wondering if there are more:
http://www.alldatadiy.com/alldatadiy/DI ... /178004414
Thanks
