mattyfo0z »
https://forums.nicoclub.com/mattyfo0z-u182195.html
Tue Apr 24, 2012 5:31 pm
So I figured out where the 2 wire harness harness connects to, it goes up a little into the wheel well (under the plastic) into a plug, then that plug goes into the main engine harness. One question, though...
The part of the harness that connects to the brakes has two colored wires, one black and one white with a black stripe. Those two go into the plug, and the other side of the plug comes out with two wires as well - but one green and one red. Before I cut the plug out of the whole situation and solder the black to the red and white to the green, I want to make sure there is nothing going on inside the plug that gave Nissan techs the reason to change the wire colors. But, if not, then the red wire INTO the plug turns into black when it leaves the plug, and the green wire turns into the white with a black stripe on the way out of the plug.
