ABS, TCS, Slip, and Low Battery Charge Warnings
kimrober
Car: 1996 Q45t, 2002 Q45
Yes, they're finally here. Last night, ABS, TCS, Slip, Low Battery Charge messeages appeared on my 1996 Q45t. The cars runs fine, I'm not really sure what's wrong. I found parts price on http://www.infinitipartsusa.com and they were very expensive if I had change these parts..
ABS actuator.................$1,270.19ABS control module.......$1,222.16TCS actuator.................$ 899.51
Q45tech
Alternator is failing [early warning sign] not supplying the correct minimal voltage to ABS and TCS computers..............replace alternator and a new battery if more than 2 years old.
kimrober
The car has been making buzzing noise at the start up.I guess it's TCS related, and after awhile it used to light up slip and TCS OFF signs. Now with all these lights on, the car doesn't even make buzzing noise anymore. The battery is almost new, just replaced it 2 months ago.I'll try to replace the alternator. Thank you!
Q45tech
Before you replace alternator check connections and use an alternator tester to measure ripple just to make sure. Could be that simple but unlikely.
Always uses an alternator from oem as aftermarkets [even BOSCH] have a very poor reliability record in Q45 application...............eventually people get tired of changing them and changing them and changing them and finally take the OEM advice.
kimrober
The car stalled on last Saturday and had to call towing truck to haul it to local shop that always works on my Q.They called me this morning that they would replace the alternator with the one made by Denso (Japanese brand he said) and they weren't sure if they're OEM or not. Total came out to be around $530 including labor.I hope this one last... Thank you
