ABS?!?
hondah8n
Car: 1995 240sx
i have a 95 240sx se model. did all se models come with abs or is it possible that i don't have it on my car. when i slam on the brakes i dont feel the usual pumping as i do on other cars with abs?
eddiec
Car: 91 S13
there several ways to tell. look under the hood and follow the brake lines from the brake master cyl. if they go str8 to the wheels then you have no abs. if the lines go to a box of sorts and then goes to the wheels, you have abs.
you can look at your front wheels and see if there is a speed sensor on them.
also when you start the car and all the warning lights light up, if you see abs, then you have it.
deezlins
Car: 95 240SX SE
no, all 95 SE's dont come with ABS, it was an option. My 95 SE doesnt have ABS.
hondah8n
Car: 1995 240sx
yea you would think it would be as simple as lookin at the dash lights but they dont work, well most of em do but not the gas light so i figured the ads light doesnt work. thanks for the help guys!
