Mine does not have any abs problem, nor air bag thank goodness, I have that scanner from prior to my purchase of the M45. I however did try to read abs codes but the scanner says no communication with the module when I try to read it. I tried reading air bag codes just to see if it will, it tells me there are no stored codes, which is what I expected.kp1 wrote:Wow thanks for letting me know will it read the abs problem ?
