ABS sensors testing .
jaimster
Car: 1995 j30
ABS light on therefore i think i need to test the ABS sensors i have located where the yare , any body knows best way to test them : checking tolerance or voltage readings what should they read?
i got the car on all 4jacks stands right now . so i didnt whant to set the tires back on . thanks :)
yodawill2000
Car: 94 Infiniti J30
Are you sure its not the relay under the hood back by the passenger side firewall ?
If its stuck it will buzz after shutoff, and the abs light will be on when its running.
I have to bang mine with a screwdriver every once in awhile.
That shuts it off and the buzzing stops.
jaimster
Car: 1995 j30
i dont thonk i hear any buzz noise when i shut off the car and thought i swapp this relay with another and light was still on. ill have to check it out again - or how would you test the relay with a meter.
driverdriver
Car: NICO's longtime resident Canuck!!!
If you don't hear a buzzing, likely culprit is that the ABS pump is done.
fourdrinie
Car: 2019 Q50
The brake section of the FSM has the relay testing procedure, page BR-62
Mkiisupra
Car: 95 Infiniti J30t
I would check to see if the sensors are dirty before assuming anything is defective. Assuming is a good way to waste a lot of money.
jaimster
Car: 1995 j30
thanks guys ill check the relay testing procedure and also ill check the tolerance on the abs speed sensors .
if all that is good ill go after the pump.
what else could be right!!!!
