ABS sensors: Aftermarket?
yeldogt
Car: 02 Pathfinder 4X LE (X2)
My independent is telling me that both sensors in the front are bad ... he thought it odd that both are bad .. he ohm them and they are. Back is fine. The Nissan are $110 - $125 each -- the aftermarket are all over the place price wise -- some as cheap as $20 bucks.
Anybody do them recently?
yeldogt
My listed prices for the OE were on E-bay .. Was able to get both OE in bags for a bit over $200. Since I'm having it done don't want issues.
yeldogt
Ended up being a big job -- each sensor is held on with one bolt that with some penetrating oil was able to be removed ... the sensor itself was unfortunately rusted firmly in place inside the hub and had to be drilled out. This required the rotors to come off ... took my Indi a long time. $450 labor and the two OE sensors a bit under $250. My local dealer wanted that much for one.
