ABS-sensor speedometer signal using a dakota digital SGI-5
Ztiggi_
Car: 1991 200sx s13, 1969 510, 93/98 fireblade turbo
Hi, i have done a engine swap, and ant to run my speedometer with the rear abs sensor and a dakota digital box sgi-5,have anyone done this before and know how the setting should be on the box?
hav tried a lot today with different settings, the box gets signal in, but the speedo wont work,(tacho was no problem)
Ztiggi_
i found the solution on this,problem was tha i was trying to use the speed signal at the white contact near the ecu, but that's an output to the ecu,
hooked up at the Yellov/green from the rear abs sensor and the Yellow/blue behind the speedometer and then it worked ;-)
