ABS Sensor Problem (J30)
J30Guy612
Car: 1993 Infiniti J30
Hey guys, while installing a new driver's side front spring (old one actually snapped) I couldn't figure out the proper way to remove the ABS sensor.
I removed the screw, and it didn't budge. Then I got a screwdriver and gave it a good whack with a hammer, and busted it open
I installed the new spring, and tightened the ABS sensor the best I could, but I am pretty sure it's no good. I am getting an ABS light on the dash, so I guess the sensor is no good.
Here are the questions I have:
Anyone know the proper way to remove those without busting them?
Know a part number to order a sensor?
Any info would be appreciated very much!
J30Guy612
Anyone know how to properly remove the sensor from the housing?
And if you can order just the sensor?
NY94J30
Car: 2000 Q45 AE
J30Guy612 wrote:Anyone know how to properly remove the sensor from the housing?
You cannot remove the sensor from the strut without destroying as far as I can tell (engineered profit). I thought abuot trying a hacksaw, but then the ABS light stopped bothering me.
And yes, you can just order the sensor from Joe, I think it is around $150.
http://www.everythinginfiniti.com
