ABS Self test?
basis110
Car: Nissan Rogue
Howdy folks,
I drive 2011 Nissan Rogue. I noticed that there's a thudding or thumping from underneath the car through the floorboard while driving in reverse and turning the wheel at the same time. This seems to happen when the car has been sitting for hours. Was wondering if anyone had this same experience? I have seen some discussion about similar symptoms being attributed to the ABS self test but my question is, do you actually feel something through the floorboard (not the brake or gas pedal) when the ABS self test is happening?
Thanks in advance.
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
Hi there, yes the ABS self test can be felt as a "clunk" through the brake or gas pedal, however if this noise occurs when turning the steering wheel I'd guess that this is not the ABS self test, but more likely a front suspension component such as the strut bearings. I discussion of "clunk" noises and the ABS self test can be seen in an existing thread:
post6267603.html?hilit=abs clunk test#p6267603
basis110
Car: Nissan Rogue
Thanks for your response kerrton.
Return to “Rogue Forum”
